Need fuel tank for 1993 four winns 180 freedom/ can't find
pilldok
Inherited this boat. Someone drilled into tank a quarter inch hole. Small fire ensued. Would rather replace tank than repair if possible after reading several options. Can not find replacement tank tho online. Searched Moeller, Amazon, Four WInns site, etc. Tank was produced by INCA. It is 19 gal below deck. It's designed to conform to the belly of the hull. 45Lx22Wx6.5H. Similar in design to attachment. Would be open to repair if someone has full proof solution. Don't want another fire/explosion!
Looks like INCA got gobbled up in corporate mergers by Seastar Solutions and maybe even Teleflex. Probably now part of Moeller. Looks like the smallest Moeller belly tank is 27 gallons, which probably won't fit unless there is lots of extra space in the fuel tank bay.
As AD indicated, you could have a tank made (aluminum) to fit your exact dimensions. Thinking it will be about $400-500 or so . . .
