Need help determining correct replacement
DUSTYCAT
i have just bought a 14ft princecraft fisherman ,it is approx 2004/2005 but there was no drain plug, (bung ) and i have no idea of the proper size ,and due to my location i will have to send for one from some where,i know this might be a silly question but any help would be greatly appreciative,thanks in advance dusty
DUSTYCAT
i have just bought a 14ft princecraft fisherman ,it is approx 2004/2005 but there was no drain plug, (bung ) and i have no idea of the proper size ,and due to my location i will have to send for one...
Re: Need help determining correct replacement
Most small boats have a 1" hole.
Most 1" plugs, are slightly adjustable, by turning the handle.
DUSTYCAT
thank's for the quick response,i had a old i"plug,but it seemed to be loose,i have tried looking fo spec's on this small but (very important item) but to no avail,any sugesting.s the plug i had was in good shape tanks again dusty
steelespike
Try contacting Princecraft.You might find some sort of plug at the hardware store.If yours has a lever you can usually turn it to adjust and than flip the lever to tighten.
