Need help finding Osco risers on Penta 5.7Gi-E
VIPNiSS
Hi guys. After much reading I decided to go with the Osco risers. Does anyone know the part numbers I will need for this? I tried looking but not much luck. Also are their gaskets any good or should I go with oem volvo?
engine serial 4012116275
Senior B
Re: Need help finding Osco risers on Penta 5.7Gi-E
I got mine there at Ebasic power. Barr/Osco Manifold&Riser kit with gaskets and all new hardware. Happy as a clam with them. Very easy install. I went with the OEM Volvo Metal Riser Gaskets and copper gasket sealing compound. I torqued to 25 foot pounds and have had no leaks or any problems. Hope this info helps and good luck.
VIPNiSS
i just ordered the osco/barr risers and manifolds.. then i ordered the volvo gaskets.. are you suppose to put copper gasket sealing even on the volvo ones?
jerryjerry05
For future reference. Cobe Marine, Pasadena,Md
He carries a ton of Osco manifolds and risers.
One of the best Volvo parts guys too.
