Need help in finding a really cheap, small engine carb tool, Pac Man #308535003
Big Bubba
Hello everyone,
I need help in locating a really cheap small engine carb adjusting tool to adjust the carb low and high speed adjustment screws on a Ryobi model S430 weedeater. The screws on it have the pac man type and I do not own this tool. Does anybody know where I can purchase this tool at a extremely cheap price? I see they range from $20 to $40 but was hoping top get it cheaper than that.:confused:
MTboatguy
Re: Need help in finding a really cheap, small engine carb tool, Pac Man #308535003
Bubba,
Did you try to look on ebay? That is probably going to be your best bet.
Grub54891
I knowwhat your steppin in,I tookmine out,used a dremmel with them skinny cutting wheels,made a slot in it,it worked.had to use a surgacal plires to get em out as ny needle nose were to big.
Cofe
You can use an electric wire splice by carefully smashing it to fit with needle nose pliers. I ended up buying the proper tool on ebay awhile back.
Big Bubba
Thanks to everyone. I forgot about checking with my local small engine supplier here in town and he had it for $15.00 plus a little tax added to it was well under $20.00 so he was cheaper than on-line. Thanks again.
