need help locate engine coolant reservoir or there is not one in my boat?
banhtrang
hello,
I have Mercruiser 94 5.0 Serial 0F153370 I try to find the coolant reservoir but can't seem to located would someone show me where to look
thanks
Bt Doctur
Re: need help locate engine coolant reservoir or there is not one in my boat?
usually hooked to the heat exchanger overflow nipple.
Pictures are worth a thousand words, especially if you have an aftermarket kit or you don't have a closed cooling system at all.
hello,
thanks
Ayuh,... It you don't see a radiator cap, it's probably raw water cooled...
banhtrang
I dont see any thing resemble the coolant reservoir probably I dont have one just like Don said. ...."heat exchanger overflow nipple..." not in my vocabulary...:)
banhtrang
My boat is raw water cool...I dont have any radiator
thanks
