need help no start
DUNK51
installing gauges and now no spark. I have been upgrading this boat for about 3 months and I started replacing the gauges and now I have not spark. Are the gauges tied into the system and causing the no spark problem? I am a life long mechanic on autos and heavy equipment. but definitely not a boat engine mechanic. please help!
Look at the model # again.-----Is there a big red plug on the wiring harness ?
Sorry....turning over I take it.
Grounding wire is still grounded most likely. Race is correct. Unplug the red plug and see if it starts by jumping the solenoid.
That will prove that you are hooked up to the wrong wire maybe. Might be a non compatible tach.
Make it run, then you know it a control box issue.
Need to confirm the model #---- Not sure if that model # existed in 92-----Unless it is a -----E150GLENC-----?????
DUNK51
I WILL TRY THAT / RIGHT NOW NO GUAGES ARE PLUGED IN. I THOUGHT THAT MAY BE THE PROBLEM.
DUNK51
THERE IS A BLACK WIRE WITH A WHITE COMING OUT OF THE ENGINE HARNESS THAT IS NOT CONNECTED. COULD THIS BE THE PROBLEM
DUNK51
SORRY TO MANY ONES E150GLENC IS CORRECT. I AM GETTING TO OLD. MISTAKES COME EASY😊
Well you know it's not the engine or it's components. Not sure which wire your talking about but my next place would be the key switch.
But just in case you do old dumb things like me let's add, is it in neutral? And is the man overboard tether clipped into its spot?
DUNK51
The theater switch is on black and yellow not grounded. in in neutral. I will look toward the switch today. finished installing carpet yesterday. now I can focus on the spark problem today. thanks for your help!!
DUNK51
it lives !!! you were right on!!! one to many black wires on the ignition switch. I WANT TO THANK EVERYONE FOR THERE HELP!!!!!!!😅
