Need help with steering cable part number SSC7215
s_explore
I have this 15 feet cable that needs to be replace. I can only find on the internet the quick connect, nut mine as a nut at the helm. Are they still manufacturing those cable?
Fun Times
According to NLA marine, seems your findings are on track,
Might be worth a call or live chat, https://www.marineparts.com/p-27816-15-safe-tbig-t-steering.aspx
Probably to small but there's a used 14-ft in here,
Found a 25-footer still new,
https://www.greatlakesskipper.com/t...-t-big-t-rotary-old-style-boat-steering-cable
Just for reference, the image below is what the Octopus Steering Cable Adapter Kit f/TFX SSC72, Uflex M47 & Morse 304415 is for... To bad there wasn't an adaptor style that would go from a newer quick connect cable end to a threaded end for a case like this. :unsure:
For sale is a steering cable adapter for use with Octopus Type-S and Type-T autopilot drive mechanisms. It allows the Octopus drive to be connected to Teleflex SSC72, Uflex M47, and Morse 304415 steering cables. It may also allow the connection of other steering cables that have the same dimensions as the aforementioned steering cables. Please thoroughly research your steering cable to ensure this adapter is the proper one you need.
Davetowz
New steering systems don't really cost much and with age, they probably could use a refresh also. and eliminate the NLA cable issue plus get that like new feeling from the steering.
