need help with timing
sustanetti
need help with timing spec on 95 force 120. some say 28 some say 30 at wot. I've even read 32 at wot. can someone help.
I watched the tutorial but I don't have safety switch on mine that I can find other than that looks about same. could it be somewhere else on mine?
jerryjerry05
Re: need help with timing
Believe your's is set at 30 to get 32 at wot.
Your shift interupt switch could be in the shifter.
Post some pics of the stbd side where the towershaft is.
And the control,too.
sustanetti
yes it's on the shifter. I thought it had to be wot in gear but I figured it out.
timing is right on 30 so I left it alone. now off to the sinc and link. having trouble getting float pins out.
got one out two thirds out and the other won' t budge. what's the trick here? I can get mean with it but don't want to break the post that hold it
jerryjerry05
Check the ends of the float pins.Some have a knurled end and won't come out but one way.
A tap,tap,tap with a tiny hammer?
