Need installation help for Steering Wheel Replacement
Trackerman
Need help please -
I purchased a Uflex Steering wheel to replace my wheel on a 2000 Sun Tracker pontoon boat. I removed the steering wheel nut/washer, the wheel will not come off. Seems that it has a fitting on the shaft that I'm not sure should be pried out or ??? And how should the new wheel be installed; is there any fitting I should be getting??
Dakota47
Re: Need installation help for Steering Wheel Replacement
a steering wheel puller is needed, and the new wheel will be pushed on by the new bolt/nut..
Trackerman
Thx a bunch. I thought it might require a puller. 2 questions for you - 1. Do I go to the manufacturer and order a new bolt/fitting and, 2. how about the puller itself?
Ps. thanks for helping on this !
Run the Nut back on, til it's Flush with the end of the steering shaft,.....
Sit in the seat, firmly plant your knees under the Wheel,+ apply All the Pressure you can to the Wheel with your knees,......
Then Wack the Nut with a Hammer,.......
The Wheel will Pop Off the taper,+ you can remove the Nut, then the Wheel......
Trackerman
Thanks again....that worked, no problems with the new wheel --- it bolted on!
