Need Mercruiser replacement prop 48-47706-a1-23 b
Starcraft Enterprise
Looking for replacement prop for my Mercruiser III. The #'s on the existing prop are 48-47706-A1-23 b. Out of curiousity, what are the specs on this prop? Does the 23 on the end mean 23 pitch? FYI, odd prop, very large, 20" I think. 1969 model if that helps.
Re: Need Mercruiser replacement prop 48-47706-a1-23 b
Ayuh,... As you may know by now, those drives were a flash in the pan, 'n are no longer supported by Merc...
You'll probably have to have yer prop rebuilt, as I've never seen replacements available for 'em...
'n Yes, the 23 is/ should be the pitch...
The rest of the numbers are just part numbers...
