Need outdrive part identified
Re: Need outdrive part identified
It's an Alpha I Gen II upper gear housing. The gear ratio should be on that decal on the side of the drive showing in your picture. That is what would determine what size engine it's for.
Brand new uppers gear units with warranty, are available from SEI for $600, so that should give you an idea of it's worth.
JustJason
you have an alpha 1 gen 2 upper. What it's worth is whatever you can get for it.
davidwjacob
thank you guys for the fast reply. i appreciate it.
hope you have a great weekend!
Dave
