Need prop ID help
Pappy24
I have a stack of older props of various sizes. Have some that I can not find which motor these fit. Example OMC 382702. Is there a reference to pair up these odd props with the proper motor/outdrive? Thanks and be safe on the water.
Is that Number correct? I can't find it on any OMC part Database
14 X 13 A low Pitch prop for
71 - 74 50hp
Most, but not all 3 cylinders
1969 and newer Crossflow V4s
some Looper, V4s
Pappy24
Need help identifying these props please.
I have 2 aluminum Michigan 4 blade props 10 inches in diameter. Stamped P12 and AMC 445. Any help would be appreciated. Be safe and God Bless America..
Pappy24
Need more prop ID help please
I have 2 Michigan four blade aluminum props. 10 inch diameter .Stamped AMC 445 P12. Any help identifying these would be greatly appreciated. Be healthy and God Bless the USA.
