need some help on base timing on a 2003 mercury 125 2+2 outboard
dog22
I have a 2003 mercury 125 2+2 outboard does anyone knows what the idle base timing should be on this motor
Maximum timing advance is most important.-----Timing where throttle plates open is important.-----Where the timing is at smooth idle does NOT matter !-----This motor only runs on top 2 cylinders.----Bottom 2 carburetors kick in at around 1800 RPM.
Dave1027
Base timing is supposed to be set to make the engine idle at about 650 rpm. So base timing is not set to a timing spec. It's set to an rpm. Max timing is set to a timing spec. On mine (I have an older model) I believe it's 25 BTDC.
