Need the part number for nuts that go on the studs which hold down the power head...
on_ice
It's no where to be found in the schematics, does anyone know the part number for the nuts that go on the studs for the power head? There are 8 of them. The motor is a 1988 Mercury 45 hp Pro Fifty/4 cyl 2 stroke. Falls under serial numbers 0B110789 and up.
Also, if you have it, the part number for a replacement key labeled 1F.
Thanks!
Re: Need the part number for nuts that go on the studs which hold down the power head
They should be standard fine thread nylon locknuts in stainless steel. On the larger HP motors they are 3/8" Your's may be smaller in size.
on_ice
Seems to be the right size. Would you happen to have a part number? I don't know that I trust the stainless steel quality from Lowes or Home Depot.
look on the crowleymarine web site for the part listings. Wait until you see what Merc charges for them.....
on_ice
Found it. It's part number 64809 according to ********** customer service man. They were $1.08 a piece.
