need throttle linkage for 57 johnson
rolmops
Re: need throttle linkage for 57 johnson
Hello.<br />Please describe the exact part if possible with serial #.I am taking a '59 supersea horse apart and I think the throttle parts are the same so I might be able to help you .
maze
hi rolmops i have rjel-19 this part is were your throttle from boat hooks and has gear to were tiller would be and goes to a shaft upward about 6 to8 inches toward top and arm to go to carb
rolmops
hello.<br />So what you need is the sprocket like part with the little handle where you hook up your accelerator cable? Or do you need more parts?<br />I am not sure if these really are the same on the 57 and the 59.I just compared the part # and the '57 gear is #304814 while the '59 is #305387 This sounds like a schematic to me.Maybe he can make us a bit wizer on this one.
maze
romops your right the parts i need is 304814 and304198 but thanks for effort gene
Chinewalker
Hi Maze,<br /> What you need is the "Throttle Control Gear" for a 35hp Johnson. The one that has the peg out the bottom that pivots and has the arm with the nub on it that your throttle cable clasps to. Correct? I've got one - and I might even have one the right color - Holiday Bronze!<br />- Scott
maze
hi chinewalker thanks for reply interested in part email is wd8maz@aol.com name here is gene thanks scott<br /><br />3
