Need trailer recomendation
carpman
I just bought a starcraft superfisherman the 19'6" model and it's a 2000. What would I be looking for in a trailer for it? What models would be the best?
Re: Need trailer recomendation
Karavan KCB-2800-DB-82-L
or KCB-3100-DB-82-L
carpman
Thanks you very much, will look into them. Is the only place to get them at the dealer?
bonz_d
I don't have any particular model to suggest though I will state that I am unbiased as to type of trailer. Bunk, Roller/Bunk or Full roller. Properly fitted and set up one is as good as the other in my opinion. Each has drawbacks. Painted or galvanized? Brakes, brakeless? What is the total weight, boat, motor, gear, fuel? What type of ramps will you be using? Shallow/deep? Fresh water/saltwater?
My preferance because of the way I use mine is a roller or roller/bunk because I launch most of the time at shallow unimproved gravel ramps that a bunk trailer would never be able to get deep enough.
Hope this helps and at least gives you some points to ponder.
