New alternator, still low voltage
MarcelSydney
Hi all.
1999 Maxum 1800 with a 4.3L V6 Mercruiser. Serial numbers are OL323311 (engine) and OL509362 (Transom).
I have been getting low voltage from my alternator. 12.3v. In the last few months I've put a new battery and new starter. Cleaned battery terminals.
I had a leaking power steering hose and it coated the alternator, figured maybe it was ruined.
Replaced it with a new one tonight, and still only get 12.3V??
I noticed that the helm voltage gauge isn't registering voltage either.
Any ideas of where to start looking? Maybe a bad ground on the engine block?
Is there something obvious I'm missing?
Thanks a lot
Have you tested the Voltage Drops along the Circuit?
What is powered, that draws a large Electrical Load?
Bat and ALT measures 12.3V
It's either the ALT or the wiring
The ALT has 3 wires, orange main power, red/purple since, purple excite
Orange = Bat voltage, should read same on starter post
red/purple = Bat voltage with key ON or OFF
Purple = Close to Bat voltage with key ON and 0V with key OFF
If voltages are correct than it's the ALT
Hi all.
Thanks a lot
Ayuh,....... You need to clean Both ends, of Both battery cables,...
By clean....use 150 grit and make the terminals shiny enough your mother in law would eat off them
If the cables are crunchy, replace them
When done, seal the connections with marine electrical varnish
The guys bring up a good point. If motor starts and idles at 700 rpm then the ALT may not start producing power. Motor needs a quick rev (about 1500) for split second then back to idle
MarcelSydney
Thanks all.
I'll check the other end of the cables.
Yep, even at around 2000rpm, no increase in voltage.
What is the Voltage of the Battery, unhooked? And after it is charged with a Battery Charger?
MarcelSydney
Hi all. Thanks for all your suggestions. Its been cold and non stop rain here for nearly 2mnths and I finally got back on to this job this weekend.
After testing everything, getting very strange readings and even querying the shop I bought the alternator from, it turns out I messed up a few months ago when changing the starter motor.
After tracing the wires from the alternator again, it turns out the main orange power wire that runs from the alternator and heads to the starter wasnt connected at all, and was hiding. So the alternator wasnt pushing power to the battery at all!. šŸ¤¦šŸ»
Once that was connected, bingo, charging again 14+ volts.
My fault.
Thanks again
