new intake...what to do with choke
sparky71
I had to get a new intake.It is the same one I removed except for where the choke mounts,the old one was flat about 1 1/2" lower than carb base. The new one does not have that flat spot,rather it angles up to carb base and has a port ( for egr system)I was told I can just block off that hole.
S o has anyone run into this?Can I just run it with no choke.The old choke is the "stove" type that I'm not even sure was working when motor came out.
Any and all help greatly appreciated.
Thanks Dan
Re: new intake...what to do with choke
Ayuh,... Convert it to an electric choke...
