New rigging wire question
5150abf
I got all the stuff to rig my new engine, F50, but at am a loss on the wiring.
I bought it through work, a boat company, our engine guy, certified Yamaha installer, is going to hang the engine but I want to have as much done as possible for him
Off the tach, ProII, I have black and blue wire out of the same grommet, yellow black and green out of the same grommet then a pink/red out of a plug.
From the key switch there are a red, yellow black and green.
I have the tach/oil sender harness but that is just a plug off the back of the tach
What goes with what?
colors are standard
however if yamaha follows them, I cant be certain.
what does the rigging manual tell you ?
[h=2]American Boat and Yacht Council Standards[/h]
BlackGroundNegative / Neutral Main Return
Blue-StripeTilt up and or trim outTilt and or trim circuits
BrownAlternator Charge LightGenerator Terminal or Alternator Auxiliary Terminal to Regulator
Generator ArmatureGenerator Armature to Regulator
PumpsCircuit Breaker or Switch to Pumps
Brown w/YellowBilge BlowersCircuit Breaker or Switch to Blower
Dark BlueCabin & InstrumentCircuit Breaker or Switch to Lights
Green or Green w/Yellow StripeBonding SystemGrounding Wires (if insulated)
Green StripeTilt down and/or trim inTilt and or trim circuits
GreyNavigation LightsCircuit Breaker or Switch to Lights
TachometerTachometer Sender to Gauge
Lt. BlueOil PressureOil Pressure Sender to Gauge
OrangeAccessory FeedAmmeter to Alternator or Generator
Common FeedDistribution Panel to Accessory Switch
FeedAccessory Circuit Breakers or Switches
PinkFuel GaugeFuel Gauge Sender to Gauge
PurpleIgnitionIgnition Switch to Coil & Electrical Instrument
Instrument FeedDistribution Panel Electrical Instruments
RedInstrument FeedDistribution Panel to Electrical Instruments
Power FeedsPositive Main Power (particularly un-fused)
TanWater temperatureWater temperature sender to gauge
YellowGenerator FieldGenerator to Regulator Field Terminal
Yellow w/RedStarting CircuitStarting Switch to Solenoid
COLOR ITEM USE
boscoe99
5150abf
Motor just dropped today and I just got home so haven't looked at the manual yet.
There are couple guy sat work that do that all day, so if I can't get it no biggie, just wanted it as far along as possible for them.
Of coarse I pull the box off and there is a giant hole in the cowl and a scratch down the side from shipping damage.
It will be made right but still.
I am jazzed, back on the water Saturday!
Thanks guys, gonna go try to sort this.
