New steering cable, oil or grease?
sickboy
So I just replaced a brand-new steering cable, tilt tube, added a sea choice steering guard nut and I have the small plunger for lubing the zerk.
My question is should I lube it with oil or grease for the cable inside the tilt tube?
I know to use grease on the motor mount/tilt tube.
Suggestions, insight, etc...
Thanks.
Ayuh,.... Same grease,.... Probably a Good place for Merc. 2-4-C grease,....
