new to "Mariner" with a few questions..
LilRedNeckGirl
Ok, here we go. recently dowbnsized from a 248 wellcraft sportsman w/ twin mercruisers.
Just bought a lil 16 foot center console. It has a 60 hp Mariner on it. Ser# L 305527. It is a two cylinder , carb style, 2 stroke, electric choke & start.
from the SER#, can anyone tell me what year it is?
Also, its 2 stroke, but nothing on the engine saying what the mix/ratio is. Any one know this .. ????
As its been years {10** since I was being pushed around by an outboard, and this is a first "Mariner" any info on these engines would be of great help.
Just picked it up, runs great on a hose connection, water trial as soon as the reg /papers come back.
Im ordering the manual, add that to the long list of manuels i have boyught over the years.
Was told that Yamaha Japan made these engines. Is that correct? It does have a "JAPAN" stamp on it.
Again, any input is appriciated.
Lisa
carholme
Re: new to "Mariner" with a few questions..
There should be some letters/numbers in front of the s/n and for the 60, that might be 675 or 6F0. Could you please check and let us know?
Yes, some of these engines were built for Mariner by Yamaha.
Gerry
LilRedNeckGirl
675 precedes the serial number. they are printed on the plate.
carholme
That s/n comes up as:
60 EL 675-305096 - 675-307910 1980 2-Cyl, Japan
From here:
Mariner 60-350 hp, produktions?rslista, modellguide
Parts List:
MARINER 60 - Mercury, Mercruiser, Force, etc. Parts Lookup
Until you get your service manual, here is a link to the condensed version of the Clymer manual to help you get started. Download it soonest to your computer as the link is short lived.
MARINER - MARINER 48 AND 60 HP (2 CYL.).: Small Engine Repair Reference Center Home
Gerry
LilRedNeckGirl
apriciate the help. I am at least a week away from getting it wet, so no rush on the manuel. thanks for the link, but the manuel is ordered and should arrive in 6 days.
We are removing the front closed bow area, and installing a few ribs, and flooring. past that, the engine will get a lower unit fluid change, pull old prop to get size, and order a spare prop. then its a simple fuel pump out, new fuel filter and lines, new plugs, install a water seperator, grease a few fittings, and it should be ready to do a shake down run.
Ill let you know how that goes....
You should install a new water pump impeller.
