New to me 9.9 Merc
Barnacle_Bill
I just bought my first 4 stroke outboard. It is a 2000, 9.9 Merc. What oils do you prefer in both motor and lower unit?
Rodbuster
Re: New to me 9.9 Merc
My new 9.9 says 10w30 four stroke outboard oil.Gear lub says Merc or High Performance gear lub.
Faztbullet
I use the Starbrite 10W30 Synthetic blend in my customers 4 stroke outboard and the Sierra 18-9680-2 full synthetic gear lube vs the 18-9650-2 synthetic blend due to the the full is used in the Volvo unit. I subcontract service to a customer that has about 35 Volvo units and about 100 Mercruisers in dry-stack along with about 75 outboards and since I switched the unit over to it I have not had any leaking seals or drive failures in 3 years and some unit are 12+years old......
http://www.starbrite.com/productdet...at=4 stroke Outboard Oils&ProductSSCat=10W 30
http://www.firstchoicemarine.com/p-30971-sierra-synthetic-gear-lube-quart-18-9680-2.aspx
