new to yamaha. tiny tach
hipster dufus
have been a tohatsu guy in the past. now i own a g3 1756 cc w a f70 yamaha. has anyone installed a tiny tach on one before? i seem to be okay with the idle setting . i dont believe iam getting a true wot rpm reading. it wont top about 4400. wot should be above 5k. i really use it for hour reading but would like to know my wot setting. thanks ahead of time
verify the tach with a hand-held optical tach. Optical tachs are about $10 on amazon
Sea Rider
If TT was installed correctly matching X spark per revolution your OB works with, could be a prop/load issue. Was OB factory delivered with a prop, if not , did someone installled it ? if so, that prop is not what your combo needs, if OB runs top will need to go for a less pitch to pull wot revs up. What's the min-max wot rpm range factory stated for that 70 HP ?
Happy Boating
hipster dufus
new rig with factory prop. contacted tiny tach, engineer said set tach at 720 degrees. will check on next run. currently have 3.75 hours on engine. use tach primarily for hour meter. would like an approximate rpm reading.4400 isnt close
99yam40
There is no prop that comes on a motor from the factory.
Yamaha has no idea what boat the motor will be put on.
Someone decided to put that prop on, they very well could have made a mistake.
If it was me I would put a Yamaha tach on it, it will give a lot of good info, not just RPM
