New Water Pump, Telltal? Not Telling
monstertails
I just picked up an 1996 pontoon with a 96 75hp Mercury and I replaced the complete water pump and fired it up. I am getting water mixed with exhaust and when i remove the brass plug just above the top cylinder it sprays out with good volume but there is a hose that comes off the top side of the block end exits out the side of the outdrive that I assume is a telltale and it is bone dry, unless this is some type of crank case breather. Can someone please assist me with this issue? Thanks in advance.
jheron
Run a wire or weed wacker line through it to clear out any potential blockage?
Cheers,
Jon
emoney
First thing I would do is run stiff line or short wire. They pick up more junk than you’d realize. That Definitely looks like your tell tale line.
Texasmark
It is and it does and wasps, the little fast flying suckers, just love to put a larvae in the end and your key socket and any hole they can find to stick mud and an egg into. You boat in salt water? How was your impeller when removed?
wn6ngp
Your first pix is correct, that is the tell tail/tale on the port side. the 2nd pix I can't get my bearings to know where I am looking. Am I looking straight on at the head? This is what mine looks like on a 90elpto 2000 year model. that is where I am measuring water pressure now. I assume its rather hot water.
the red cable is my attempt to measure temperature by putting a sensor probe in that hole. Not sure what the purpose is of that castle like piece sticking up.
monstertails
WOW Unbelievable!!! There was all type of stuff blocking the line from rocks to stuff that looked like paper. Thanks everyone!!
Texasmark
Monster, glad you got it flushed out.
Wn6, the second pic is the inside view of the back of the adapter that plugs into the starboard side of the lower engine cowl.
Measuring water pressure there is water pressure in the exhaust cover plate, not engine crankcase. The brass ⅛" NPT plug on the rear of the block water jacket...encircling the spark plugs is the access point for engine block cooling water.
wn6ngp
"The brass ⅛" NPT plug on the rear of the block water jacket...encircling the spark plugs is the access point for engine block cooling water."
Is that an ok spot to measure pressure? Watching gauge I can see the pop-off valve operating, it apparently opens to let water bypass if pump pressure gets too high.
