NGK Plugs
pennyduke
I have a 1993 mercruiser MCM 5.0L serial 0f002209.
My drive is a Gen 2 serial number od899770.
I want to install new NGK plugs and I get 2 different numbers when I look them up. Can anyone tell me the correct plug number. Thanks
Fun Times
Re: NGK Plugs
Look for old mercruiser part number 33-59571, (NGK BR6FS), Or if you can't find any of those numbers at a mercruiser dealer then the new part number for mercruiser is 33-898264001, Because mercruiser is now going back to using AC SPARK PLUGS.
Re: NGK Plugs
Ayuh,... AC Delco, MR43T...
achris
More fish than mountain goat
Re: NGK Plugs
If you want to use NGK (I do) then the right one is BR6FS....
