Nice Turn
Re: Nice Turn
Weeeee, all hands please hold on!!!!
qaztwo
Re: Nice Turn
I remember watching the building of a aircraft carrier on discover once, and they showed them taking it out and putting it through the ringer. One of there test was full throttle and full rudder. Every one on deck was leaning about 30 degrees to stop from falling off, I thought it was neat.
Barlow
Re: Nice Turn
its not turning.. its called a "power-slide".<br /><br />get'er goin' at WOT and as soon as you feel the need, at the same time now, dump the throttle into neutral and crank the wheel to hard lock left..<br /><br />Did it in the MasterCraft all the time :D :p :D
dogsdad
Re: Nice Turn
I can't imagine being on a tube behind that monstrosity!
NYMINUTE
Re: Nice Turn
. WhoooooooooHooooooooo
cbnoodles
Re: Nice Turn
Only problem here was that I couldn't get her to stop listing so heavily when I heeled her over to port. ;)
silenscurator
Re: Nice Turn
I don't even want to think about what kind of stress that is putting on any of the superstructure let alone the steering and poor fisherman that are gonna be on the recieving end of those monstrous waves...
Twidget
Re: Nice Turn
I was on the commissioning crew of a guided missile frigate. Quite a bit smaller than the carrier...carrier = 100k tons, FFG = 3800 tons.<br /><br />One of the sea trial tests we did, was full ahead, 45 knots, then slam it into reverse. Perry class frigates have gas turbine engines, so it was a very fast stop.
silenscurator
Re: Nice Turn
With quite a bit more success than some of the drivers around here of late...
