Nissan
delanesr
Hi got 2001 nissan 15 hp 4stroke model nsf15b replacing impeller my question is when trying to remove roll pin i ve only got standard rollpin punchs it call for 3mm can I use standard or should I get 3mm my second question when getting ready to remove pin should I back coupling up some how any ideas thanks delane
I have never found roll pin punches to be that precise or accurate in the diameter. I would go with a 1/8" if you have one and be done. If that should be to big (.007" difference) then use a 3/32.
pvanv
Tohatsu sells a 3mm punch as well as an installer (cup).
