NMEA noob needs help
thegipper
I have a Garmin Echomap 93SV and I want to add the Garmin steady cast heading sensor. I ordered the sensor but now I need to setup a basic NMEA network.
I've found various NMEA 2000 starter kits, most have Two T connectors, two backbone cables, one power cable and two termination plugs.
The steady cast heading sensor does come with a T connector.
I need to hook up both the Garmin chart plotter and the heading sensor. The steady cast heading sensor has a built in NMEA ready cable.
Can this setup be done without purchasing any additional cables or connectors? If not, what else do I all need?
Thanks!
thegipper
To make it work, my theory looks like this:
Termination plug - T fitting - T fitting - cable - T fitting - Termination plug
First T leg would get the power cable, second T leg would get a cable to my Garmin unit, third T leg would get the cable from my heading sensor.
Hope that makes sense.
get the garmin NMEA starter kit
follow the instructions with starter kit
all additional stuff (radar, sensors, fuel flow meters, etc) gets plugged into Tees in the trunk
You need a back bone kit.
Shop around for a back bone. The great thing about NMEA is that you can mix and match manufacturers components.
I have a Lowrance backbone (best deal) connecting a Lowrance paddle wheel (best deal), a Garmin fuel flow ( best features) Garmin GPS antenna (came with chartotter) and two Garmin chartplotters.
thegipper
I actually ordered the Lowarance NMEA starter kit and based on everything I've read/seen so far, I should have everything I need to set this up.
thegipper
Thanks for the link. I looked it over and it looks like my proposed setup should work perfect.
