No Center Attachment for Hauling onto the Trailer
Status
Not open for further replies.
jlh3rd
if you have the guides. If not, that toon goes all kinds of sideways.
Jeff J
Back the trailer in deep enough and float the pontoon on
That’s what I used to do with the 24’ Fisher I used to own. It usually took a couple of tries to get it straight on the bunks.
I removed the stock guides on a work trailer. The boats kept floating over them and getting hung up.
legalfee
Or power it up on the trailer.
Jeff J
Very seldom can that be done with a 2 tube boat. Mine had a 90hp, which was max allowed on the tag, and it wouldn’t push onto the trailer if any of the bunks were showing. The 150hp tri-toons push pretty good but still end up crooked, even with guides.
legalfee
I was able to drive my Suzuki 115 24 ft Sylvan 2 tube up on the trailer. I had to give it some throttle though.
power loading is illegal in most locations. it wrecks the ramp.
DeepCMark58A
Has it ever been enforced? I do not do it because I fear wrecking stuff while there is a low impact alternative. Funny that people that spend a day on the water are so adverse to getting in the water to load out a boat.
I know its enforced on two of the ramps here in Florida, and the two ramps on the lake my buddy lives on up in Sturgeon Bay.
it only took a week of people power loading to have a spoil pile so big behind the ramp apron on the SR64 ramp at the Manatee/Braden River (just inland from Snead) the county needed to come back out and dredge.
Jeff J
While I have waded in chest deep while fully dressed and in my work boots to load boats I do everything I can to keep my feet dry. I don’t like wearing wet work boats. I grab my muck boots if I think of it before I leave the house but they are only knee high anyway. As much as I don’t I don’t want the lake in my boots, I want it less in my truck. I don’t go to the lake to swim or ski.
legalfee
First I've heard of it but I don't own a trailer and the first time I've loaded it was on the guys trailer that is working on my boat and I only did what he told me to do.
Jeff J
I haven’t heard of a law against power loading anywhere I have been. I will admit to not studying the boating regulations most places I have been, especially in states I just visited.
I have seen 2 problems caused by power loading. One is the aforementioned pile that builds up on the ramp. The second is a hole washed out at the end of the ramp. Try dragging a loaded boat trailer over that concrete drop off once. I didn’t understand what was going on until after I got the trailer up the ramp. It cost me a wheel and a fender. The lake here doesn’t stay at a constant depth. When it is 10 feet above “normal” most of the ramps are flooded or the Corps close them. When it gets 6 feet low all kinds of crazy stuff is revealed. A lot of people get stuck in the middle of the lake when it is down. Not many of the ramps were built with the lake being 4 or more feet lower than normal pool even though it happens nearly every year. Can’t see bottom in 6 inches of water most of the year.
Jeff J
I’m glad the power loading topic came up. I just searched the states where I have operated or intend to operate boats. Only one has a state law against it and I may be moving there so I’m glad I saw that. Of the others, none had a state law or regulation but one did mention it was up to the controlling authority for the body of water.
Well constructed ramps eliminate the problems with power loading.
sundy58
My wife and I load our pontoon with walkie talkies. I back the trailer in all the way to get the bunks wet. Then I pull up so she can see the guides, she pulls on till the boat stops, she maintains the throttle just above idle.I back the trailer in and the boat slides gently into place.
Status
