No compression cyl 2&3 - mercruiser 3.0l
Mischag
Hi all,
Have been very much a part of this forum stalking for a while now, and recently acquired a new to me 2000 sea ray 180 with a Mercruiser 3.0l in it. The serial number I've found on it is M018823. When I bought it, hadn't been used for about 10 months (no winterizing required here in Brisbane Australia). Had the shop do a service on it before it got sent to me.
Since then it has been unite frustrating. First off, fuel was not being pumped. After a lot of things, got a new fuel pump fitted and still didn't fix it. Put on a different fuel/water seperator and bobs your uncle. Working great! Got smart tabs, boat worked flawlessly for about an 8 hour day.
Then...
Went to take it out the next weekend, and started perfect, got out onto the lake, pulled a kneeboarder up and cruised for a bit. Stopped (not abruptly at all), left engine running, changed kneeboarders and suddenly engine had no power. Throttled back to idle, motor shaking violently. Thought it must've been mounts but after reading here, obviously not.
So...putted back to shore, and since then trying to troubleshoot.
Pulled spark plugs, all good really. Getting spark too. Did compression check, and 145 in cylinders 1&4, 0 in cylinders 2&3...
Didn't do the wet test as I read on here that to get zero, wet test won't show much??? Should I do it anyways??
Pulled the valve cover off to see if any valves stuck...doesn't seem to be...
Cranked engine and all four moving up and down...
Can I do the wet compression test with the valve cover off??
What should I do now?? No service guys out here for these motors at all....so trying to do it myself.
Have manual#26 on my iPad that I've been using...
Any help appreciated!!
achris
More fish than mountain goat
Re: No compression cyl 2&3 - mercruiser 3.0l
Sounds like the head gasket is blown across between cylinders 2 & 3.
A few things. That serial number isn't a Mercruiser number. Mercruiser numbers start with a zero, then have a letter, followed by 6 numbers.
Really???? Brisbane has plenty of Merc dealers. Where in Brisbane are you?
Chris.......
Mischag
Yeah, I suspected the head gasket as well, but I would've thought I could have some compression...maybe it's really blown...
And unfortunately, bought the boat in brisbane, but I actually live in Mount Isa, NW QLD, 900kms from the closest service centre...
That serial number is the only one I can find...on the tag riveted to the engine on the starboard side...
achris
:facepalm:... Too early in the morning for me I think. Yeah, that number is a good one... 1998 3.0L Model #4111025N2.
A decent blow will show a 0 on the compression gauge.
As far as servicing/repairing the engine, any good car mechanic should be able to handle it. It's just a car engine with a few marine bits. Just make sure he knows he MUST have water running to the drive impeller if he wants to start it. If you want to handle the job yourself, we're all here ready to advise... (and it's not that difficult).. you have the right manual, so that's a great place to start. Have a read of the instructions and make a decision. If it needs a new head, you can get them for about $800 (including shipping) from Canada. (Friend of mine just went though the exercise) The only 'special tool' you should need will be a torque wrench.
Chris.....
stonyloam
Often "0" compression on two adjacent cylinders will be the head gasket blown between the two. A wet test would show no improvement.
Took your serial number M018823 and looked it up by placing a zero in front and cam up with Merc 3.0 Alpha 1 - serial range 0L097000 thru 0W301999
