no gears when boats running
Frankiea87
i have a 88 sea ray sundancer 268 with 7.4l 454merc with bravo one drive..i was cruising along the other day and lost my gear. didnt hit anything (i dont think)..boat still revvs up and runs no problem.. when i put it into gear theres nothing... when boat is off i have forward and reverse the prop locks both ways correctly. anyone have an idea of whats wrong?
Bt Doctur
Re: no gears when boats running
bad coupler
stripped gears from low oil
broken driveshaft
prop hub
NHGuy
I don't know bravos but if you can see the very back of the engine and can see the output shaft that leads back to the drive check to see if it is spinning when the engine is running. If it's not turning with the engine you have a bad coupler. Which stinks because changing it requires engine removal. Can you smell any burning friction stink while it runs? Are there any sounds at all? Do you feel any clunk when moving shift to forward or reverse?
Frankiea87
no clunking noise at all.. just revvs up.... shaft still spins so i dont belive the coupler is bad..
180shabah
Possibly bad shift mechanism/cables.
NHGuy
Might be in your upper gears. Do bravos have a top cap that you can pull off to look?
Frankiea87
hey.. update.. its an alpha drive. also i pulled it off and when you spin prop, the yoke should turn at the same time correct? well i cant spin the prop or yoke. any ideas? (crossing fingers its not a gear issue)
Bt Doctur
drive seized from lack of oil?
muc
Hi,
Alpha drive behind a big block lasted 22 years ----- not bad.
Might be a good idea to look into a SEI replacement drive.
Good Luck Muc
Frankiea87
is it repairable? also will a bravo drive bolt right on?
Alpheus
Its repairable, but with the price of SEI drives its cheaper to replace.
And no A Bravo will absolutely not bolt up to an Alpha...
Frankiea87
where cna i get the drive from? any online sites?
