No lift eye.
redlinj
I have to remove my ‘82 evinrude 150 off the boat! No lift eye! ( if that’s what it’s called). Don’t really see any place to put one other than maybe loosen the fly wheel nut and see if one fits there. Other than that, maybe a cable under the flywheel. Any words of wit? Thanks!
I used a nut and welded 3/8" U-BOLT to it.----Or as stated use the 3 threaded holes.-------Do not use cable under the flywheel.
