no oil light on before started ??????
mikomos
i have a 1997 225 h.p. Evinrude,The no oil light come on and stays on when i turn the key on and it cycles throught each warning, Also stays on when running and buzzer goes on , The tach is acting up also jumps up and down from 1100 to 4000 rpm at idle ,VRO or could tach have something to do with it even when not started?????? Thanks
Re: no oil light on before started ??????
No oil warning comes from the OMS Pump itself. It has a sensor that determines that oil is flowing. I would recommend you test the alarm circuitry, and do not run the motor until you determine if it is indeed mixing oil, or not.
An easy test is to fill the oil tank to the top and run a couple of tanks of 50::1 premix thru the motor. If the oil tank needs a qt of oil to refill it, the OMS pump is working.
mikomos
Thank You so Much,I ordered a new VRO pump anyway,acctually two 1 for each motor figured it cant hurt? allthough spendy little things!! I hope the tach doesnt have anything to do with it Thanks again
jshane39
Was following this post and was curious if replacing your VRO's was the fix?
