No power are full throttle
paulrfrancisco
Re: No power are full throttle
In reference to one of my earlier post here in this thread,... please advise if you verified the roter is for a V6 (6 fingers, not 8.) this will make your timing all off... I had very similar issues but mine was a 8 cyl, with a 6 cyl rotor... very similar symptoms.
thisuldoit
The rotor has 6 fingers and this is for a V6.
Thanks!
I recenltly rebuilt the carburetor, so is this an idle mixture adjustment problem?
Well,.........
Now that you have it Running,......
Adjusting the Carb would be a Great Idea,............
When you get the Idle nailed down,...... You should Recheck the Timing........
thisuldoit
Follow up:
The problem was the timing on the engine. I had it set at 8 degrees ATDC and it was supposed to be at 8 degree BTDC. I fixed this problem and she purred like a kitten.
