No spark - 1994 350 - 5.7L
tevensa
Hello Gentlemen and possibly ladies, I could really use your help on a 1994 Mercruiser 5.7L -350 - had the engine rebuilt - put it back in just like I took it out (no extra parts). All of the other electrical components work great ie. starter, sumps, tilt, etc. but I have no spark at the spark plugs. Traced the wiring diagrams and they look right as it is a stock boat. I have voltage at the coil, distributor and the Thunderbolt IV ignition (which is mounted on the distributor). What am I doing wrong ? Is there a ground wire from the disributor to the intake manifold ? Ideas welcome! Thanks.......
Bt Doctur
Re: No spark - 1994 350 - 5.7L
Shift interupter or it`s wiriing.Lanyard safety at the helm
FreeBeeTony
My guess would be the wiring on the shift interupter..........I had the same problem once.........had the wire from the distributor going to gnd instead of the switch.
