no spark.......driving me crazy
jdcook
recently rebuilt 88 gm 4.3 v6. It goes in a 91 glasstream. We got the engine back in the boat, got everything hooked back up. Now we cannot get any kind of spark at all. We tested and we have power to the coil, and a new coil wire. the wiring harness is connected, and all wires are hooked up. <br />I don't believe that the boat has a kill switch, it ran before and never had one. <br /><br />there is a wire that runs out of the back of the boat into the engine compartment, it looks like two sets of small extension cord thats splits into. I don't remember them being hooked up before, but we cant figure out where they go.<br /><br />anyway, if any one has any ideas that they can throw at me, it would be great, because i am just about ready to pull my hair out.
rattana
Re: no spark.......driving me crazy
Do you have points or electronic ignition?
Rickles
Those are your trim limit and trim sender wires.One pair goes to the pump and one pair goes to the harness near the carb.or Mercathode if you have that system.
motox6
I had the same problem, come to find out that I had a bad 50 amp in line fuse where the engine harness coonnects to the positive side of the battery.
Boatin Bob
What about your shift interupt switch, this will ground out the coil if it's activated and you will never see a spark.
rattana
Are you sure the wiring on the negative side of the coil is correct? You can put a 12V test light between the positive and negative side of the coil and turn it over. The light should flash intermittently.
crazy charlie
Check your grounds,reset your main fuse button,and move your shifter back and forward and put it back in neutral.Charlie
