no spark
dubge
Well after doing some searching and reading here this is where I am at.....
I have spark at the coil but not at the plugs. I have to still replace the cap/rotor and while I am at it I think I will replace the ignition sensor (I dont know where that is so if anyone could let me know that would be great) I just replaced the wires today but have to p/u cap/rotor because the local store did not have it
Is there anything else I should check? I do have voltage at the coil, used test light because my brother had my meter but will have that back tomorrow.
oh and the ignition is a thunderbolt 4
Thanks
Ray
Haut Medoc
Re: no spark
Replace the cap & rotor & see what that does first.......;)
Re: no spark
Ayuh,......
The "ignition sensor" is Working,..... Or there Wouldn't be any Spark at the Coil......
Do the Cap,+ Rotor, along with the Wires..........
How are the Plugs,..??.....
dubge
Re: no spark
plugs were replaced a few weeks ago and wires today
will do that cap & rotor in the morning and see how that goes
Thanks
Re: no spark
The cap, rotor, and plug wires, are what distributes the spark from the coil to the plugs.
