Nobody fishing?
I think that....... The drag knob sides are cylindrical and as I cast the line the braid prescribes an acr and when I wind as the bail arm goes over there is enough slack line to allow the 1st loop to wind around the knob ...if I had noticed at this point I could save it but......so it winds around the knob untill there is no more room and then drops down and winds onto the spool as normal, and this really complicates things as trying to get the line off the spool is easy but then trying to unwind braid that has now come off the knob as per pic just doesnt happen, and there is now braid lying all over the place from where I unloaded the spool .
So I now after the cast I wind handle to get the bail arm to go over and then swing the rod back a bit to tighten the line and then wind on as normal . If that drag knob had a bit of taper on the sides it wouldnt happen and being as it chrome plated plastic ( has a metal insert ) trimming a bit off it probly wont work .🙂
Use a braid friendly reel, don’t overfill the spool and manually close the bail after a cast. wind knots go away
😃One thing I can assure you is that I am NOT going to be manually closing the bail....may as well use a hand line.😁
The spool is def not over full ...now as I have lost about 50m of line offa it in the last couple of days and I think it only held about 100m .
No winds to speak of. The breaking waves are the two currents concluding.
“The Point” is formed by the convergence of the warm Gulf stream waters coming up from the South and the cold Labrador current coming down from the north.
One of the holy grails of the surf fishing world. People come from all over the world to fish that Point of land. Fisherman are 3-4 persons deep when the “bite” is on.
Cape Point, Cape Hatteras, NC
I bought 2 x surf casting set ups and havnt used them yet. I want to go fishing for elephant fish (shark related ).
Do you use a bait cannon ?
In that picture It looks like the bail roller on the reel sits out to far as compared to the spool face allowing line to wrap around that drag knob.
I always set my bail by hand when using a spinning reel, it’s actually the proper way to use it. Setting the bail by reeling puts twist in the line every time you do it. It becomes second nature and actually faster than reeling.
Wel I had a bit of a measure up of my other spinning reels , not all of them but the ratio of spool size to the distance from the roller axis centre line to where the line touches the spool at a tangent is about the same .
I dont understand how you say flipping the bail over manually is the correct way when every single spinning reel I have ever seen does it automatically and as for twisting the line .....yep they do it when you wind on and again tother way when you cast off and any unballance there is why I use swivels ....sometimes two on bigger stuff , like all lures (not Rapala style coz they dont spin ) come with a swivel and I have a snap swivel on the line. On smaller stuff I take the swivel off the lure because the two together are nearly as long as some small lures .
Any hows last night I did the swing back of the rod to tension the line before winding on and I had no issues . Waiting untill the current pulls the line tight works too but then the lure contacts the bottom and comes back with stuff on the hook .
I fished for decades before braid came along and Im thinking I might go back to a good flurocarbon or nylon .
I went to braid mostly to stop line stretching on heavier rigs in deep salt water and sorta morphed it onto my other reels .🙂
You would at least get a line in the water…lol
Not all spinning reels handle braid very well. Found that out looking for a reel for the light tackle jigging rod I built a couple of years back.
Not all braided lines are not the same.
I jig with #15 Sufix 832 braid. Cast #30 Sufix 832 and troll #65 and #80 power pro
FWIW: I have far fewer issues with braid matching line diameters instead of line strength
Never seen one other than on YouTube
I can cast 150g weight and bait 100+ meters with no problem, but rarely need to given that most fish are caught within 10-20 meters of the beach.
I agree that not all braid is the same , I have two other combos that have some tournament crystal braid .......wanna say Berkley but honestly cant remember and they dont do it . Abu Garcia revo 2s reels.
As for the bait cannon ..... Trying to cast off a gravel beach on one leg was apparently great fun to watch but I got sick of falling over ....and getting back up was a mission , casting off a chair doesnt work either ....so bait cannon , yay.
Mostly here the Ellies ( elephant fish ) hang out behind the breakers which is not usually 100m away but ....I have a prosthetic leg ( Ottobock C-leg ) that cost more than all my cars and motorbikes put together and it doesnt like getting wet and I cant power it down or even remove the battery if it does start fizzing so I give the salt water a bit of distance .
Was the first one your bait for the second one? Nice bass you got there, Igaytan!
Looks like you had a good day .
That big one would have given you a decent scrap ?
This is what we call Bass in nz ....totally different and usually caught in hundreds of meters depth and its more like winching up a dead weight as they give up when the barotrauma hits them ....not much point in putting them back but they are good eating
Got to a pond today that the owner wanted to know what fish were in it. I went with worms and lures. No hits on the different lures and the worms started out with very small bluegill. By very small I mean 1 - 2 inches in length. Then the slabs (9-11 inch bluegills ... fat and wicked fighters on the ultralights) started. Caught about half a dozen slabs and lost about 4 or 5 more. Caught a bunch of 4-6 inch bluegill also. Caught about 30 total fish in an hour and a half while batting the breeze with the 92 year old landowner. Fun times. Pictures later.
my fav fish other than yellow perch.
they need to be on the larger size to make it worth it but very fine grained flesh
DeepCMark58A
I like to do 1 batch of bluegill a year the old fashioned way, scale them, gut them cut off the head and fins and cook them whole, reminds we of weekends at the lake with my grandparents.
