Normal for transom?
woody619
Is that board back there normal? It looks normal from the outside.
Alpheus
Re: Normal for transom?
You mean the outside where you cant see it?
You think it would be glassed over to prevent getting wet and rotting...
Ayuh,.... Looks normal on the inside too...
woody619
Thanks, no it looks fine from the outside. Was asking about in the bilge side. Trying to look for other stuff that's wrong with this. Thanks
zbnutcase
Have seen quite a few boats built like that.
HT32BSX115
It's very common.....
A LOT of boat builders don't seal the bilge area very well. As long as it lasts the length of the warranty, they're "good"!
If you ever have the engine out, you can re-glass & seal it all up and paint it!
Before:
After:
