Novice to towables
Status
Not open for further replies.
jstaz
Just wondering if i could pull one tuber using the transom tie downs as i do not have a single attachment like ski boats and dont want to install a tripod. What would be the best way to attach the cords to the tiedowns if i am able to use them for a tuber. The tuber would not wiegh more than about 175lbs
littlerayray
Your tied owns are more then likely submerged but if you can then it is possible also if you use the tie downs you may want to look into purchasing a self centering harness
RCO
If you have solid reinforced tie down eyes they are better than a ski pylon for pulling tubes. You will definitely need a self centering harness with float.
jbcurt00
Closed
Old topic RCO, its been nearly a year, and a lot of boating season since the OP asked this question.
Please check the help tips at the top of the forum or the forum rules. Best to leave inactive topics inactive.
Status
