AGENT 37
- Joined
- Mar 2, 2007
- Messages
- 319
I was gifted the subject motor a few weeks ago and was told that it "surges". Well, I gave it a look over, checked compression and found 130 even on both cylinders, tested the kill switch circuitry, and verified spark on both cylinders. I then drained the carb bowl, flushed the lines with fresh, non-ethanol 50:1, started it up and confirmed the issue. It started right up after just a few pulls and ran at a rather higher RPM than expected and revved up and down and stumbled at any throttle setting. The last guy who messed around with it had a hunch the condition was due to a faulty CD unit... Not being one to fire off expensive non-returnable parts at a project motor I decided go ahead and gut the carburetor, give it a thorough soak and cleaning, I scrubbed, sprayed and removed all jets and blew through all passages I could access aside from removing the pressed plugs on the top.
I put it back together, reinstalled the carb, and gave her a test run. Same condition but I noted that I could smooth it out by messing with the choke. I also found that the idle speed was cranked up so I shortened the first linkage from the tiller and backed the idle speed stop out. I trimmed the ends of the fuel lines due to minor cracking and distortion and re-primed the fuel lines to do a more thorough leak test. I noted very light fuel seepage coming from around the float bowl seam, drain plug, and fuel supply hose barb. I manipulated the hose between the pump and the carb to see if I could get it to seal and the output barb snapped off of the fuel pump. Sweet.
Next move was to use a double male barb to connect my tank line to the carb line and see how it would run with the fuel pump bypassed. That was when I realized the fuel leak at the carb inlet was due to a hairline crack in the plastic barb. Sweet!
Both plastic parts on the fuel pump and carb are not replaceable items so I just ordered a new carb, pump, and gaskets for both. Hopefully the breaking of brittle plastic pieces was a sign and I can get this thing going with the two big ticket fuel system items.
I also looked into the ignition system a bit. The weak looking spark had me concerned for a bit but the fact that the motor starts relatively easily and runs on either cylinder kinda throws me off. Is that how these babies are? I don't have a DVA available but I did resistance checks on the exciter (stator) and pulsar (trigger) coils and got the following readings:
Exciter = 333 ohms (spec calls for for 200-300ohms)
Trigger = 40 ohms (spec calls for 30-46)
Would the 33 ohm higher resistance be of concern on the exciter coil?
Anybody have similar experience to share or any words of encouragement to offer?
I fired off an email to Nissan with the model and serial number and they came back telling me it is a 1990 motor. It's blue and grey and in pretty good shape for a 26 year old motor living on the windward side of Oahu. I think it might do my recently purchased 1992 4M Avon Searider well if I can get it running good.
Aloha, ~B~
Aloha, ~B~
