Nuts and bolts.
sogood
Does anyone know where to source the various nuts and bolts that are used to fix the inner /outer transom plates on an alpha 1 gen 1 outdrive? I'll be replacing mine soon after my transom and stringer replacements. I can identify the ones I need, just looking for a source. Thanks.
sogood
I've looked into that and apart from the studs, which I don't need, it doesn't show the bolts on the inner transom plate, which I do need. These are bolts that fix the inner transom plate, from the inside, through the transom and into the outer / gimbal housing. Also the nuts that hold the exhaust Y pipe onto the inner transom. Any thoughts and thanks again.
Ayuh,..... The big studs, can be studs, 'n nuts, or bolts,..... Nothin' fancy,......
The y-pipe is held on by the 12-pt ssteel bolts, no studs, nor nuts,.....
Have a look here
https://www.mercruiserparts.com/bam/subassembly/30872/2203/20
The Y-pipe would be the same for motors but is listed on the exhaust system of each motor
This is a 350 mag
https://www.mercruiserparts.com/bam/subassembly/31780/1014/370
sogood
Thanks. The studs aren't really a problem. The main bolts that I need are the ones that go from the inside of the transom, through to the gimbal housing. They are part threaded and about 4.5"long by about 3/8"thick.
achris
More fish than mountain goat
