O M C cobra prop
Firstdog
I have a 1989 O M C Cobra trolling motor and can't find model # on unit need prop. It has a 8 1/2" two blade prop with a 3/8" shaft that is held on with a carter pin the drive shaft has a pin in it that fits in a slot inside the prop hub I guess as a drive pin or shear pin. one blade has a crack in it won't last long. THANKS for any help OTTIS
Re: O M C cobra prop
Ayuh,... Don't post yer email address, as the mailbox will become uselessly full of spam, 'n it's also against the forum rules...
You did read the forum rules at the top of the main forum page,..?? Right,..??
Firstdog
Sorry about that won't happen again. Found one at ace hardware but really sorry about mail post thank for the up date.
