O Ring Replacement on Drive Shaft Question Mercruiser A1G1.
1985 Century Mustang
I have a question concerning the O rings that go on the Drive Shaft l, I'm doing my upper and lower seals on the outdrive .The seal kit came with Five O rings, 4 Black and One Orange. The Orange O ring is thicker than the other 4 and looks like it will fit fine. Do I use that one towards the yoke? Or should I just use the black one. Thanks
Fun Times
The bigger O-ring towards the coupler...Should look like the image below,
148M0204650--------O-RING (.924 x .103)29845SS
$2.90$2.832
148M0204654--------O-RING (1.046)35027SS
$1.70$1.66
$2.90$2.832
$1.70$1.66
Is that a Gen2 Outdrive? I only have 2 slots on my outdrive for O rings that are towards the yoke. Photo enclosed..
Also, the lower seal I got in the kit is hard plastic and rubber unlike the upper seal, is this normal? Photo below
