Odd prop, to me anyway.
sandersps
Hey prop guys, I have a 3 blade aluminum 15x19 prop with replaceable blades. The blades bolt on from the outside of the hub. It has the # AM-BL-1519 Stamped on each blade and no other markings that I can find. It also seems to have the thrust plate and splineed spacer built in to the hub. Anyone have any ideas as to the brand? I will try and get a pic up soon.
Re: Odd prop, to me anyway.
Ayuh,... Have ya tried Googlin' it,..??
sandersps
I tried googling it several diffrent ways and all I seem to come up with is piranna composite props. I guess I will just go with a new style. I hated to give it up being that it is alumminum and the blades are replacable without removing the prop nut. But, if I cant find blades to replace, then I guess it kind of defeats the purpose.
And thanks for the reply bond-o. I appreciate it.
