Oh Boy! Got myself in a bind with new Honda
robertjp
So yesterday I bought a new Honda 50 HP (gave a deposit) and it never dawned on me that my built in gas tank in my 16 Sylvan (18 gallon Mueller) has a 50:1 oil mix in there. The Honda is 4 stroke and doesnt mix oil with gas. Now I realize I can syphon the gas out but wont the oil residue left in the tank mess up the new 4 stroke or will it be diluted so much it wont matter? I am really nervous about this as I think replacing the tank would be a giant hassle. What should I do? Thanks Bob
Sea Rider
Siphon the most mixed fuel on tank, top tank with fresh fuel and go boating....
Happy Boating
Groo
If you drain 50:1 down to 9%, then top off, you are going to be like 500:1
remember, 2 stroke oil is intended to burn. I wouldn't worry, and didn't work myself when I recently went from premix to 4 stroke and reused my cans.
gm280
its got about 15 gallons of 18 left. Thanks
If I calculated it correctly (yeah right) and you have the typical 50:1 in the tank now and you have 15 gallons left, you now have 60:1 mixture in there if you top the tank off with gas JMHO
GA_Boater
Consider it break-in oil. Ask your dealer to be sure.
This probably happens more than you think with re-powers from two to four strokes.
matt167
I'd ask the dealer but really, they have to deal with that type of thing all the time. personally, drop it down to a very low ratio and call it top end lube/ break in lube
GA_Boater
If the old motor is still on the boat, you could go out for a 15 gallon cruise to reduce the amount of pre-mix.
Just don't run out, make it a 14.5 gallon cruise.
harringtondav
Ditto all above. You'll get a little smoke, maybe need to clean up your spark plugs, but I doubt it. Keep topping off your tank, and run the Honda like you mean it. No excessive babying. I had some premix I needed to dispose. I poured it into my snaggletooth '99 Durango. No problem, except for those following me.
BillP
I had the same issue and ran about 20 gals of 50:1 in my new 50 4 stroke. Had the engine for yrs and it never posed a problem...except it took a long time to drain the tank @ 2 gph.
