Oil extracter
what are you working on? 7.4 liter (454)? if so, you are in the wrong forum. Suggest you PM a mod to move it.
Most all will work, just depends on what type and how much you want to spend. I have an electric which is mounted on a 3 gallon bucket. Many like the vacuum type.
Silverbullet555
I think most work fine. If you have s thread on dipstick making an adapter for that makes it work better. Never had great success with the tube sliding inside the dipstick. I eventually added a fumoto valve and drain that way with a tube out the bilge drain.
HT32BSX115
What’s a good oil extracter for I/O 7.5 OMC?
Howdy,
Welcome aboard!
The 7.5L OMC (Ford 460) engine has a dipstick tube that you can draw oil out of without putting a tube down inside.
Any of the vacuum type oil extractors will work. It's better if you do it with the oil warm but it will work either way.
I have a Moeller vacuum oil extractor like this:
