oil filter
cimy3
Good Evening.
I have a '89 Thompson Merc. 5.0L Alpha I. I went to the store to get an oil filter. However, the one on then engine currently is the 35-866340Q02 and the store only had the 35-866340Q03. Is there a difference? Did the numbers change?
Thanks for your help.
Ray
Re: oil filter
Ray, I used to use the automotive filter for that motor and year. I would therefore look up an '89 Chevy pickup or full size car and use the specified filter.
drrm123
Re: oil filter
store you went to should have been able to tell you if the part number was superseded? what brand part was it? if merc call a different merc dealer and ask.
betayv
Re: oil filter
hi there go to any napa autoparts and get a NAPA gold 1069 or 1060 should work without problems
cimy3
Re: oil filter
thanks guys for the info. It's appreciated.
Ray
