Oil leak found...how to fix?
kewlkatdady
So I thought I had a oil leak from my valve cover gasket, but after getting the exhaust manifold off and doing some visual inspection I couldn't figure out where the leak was coming from...
I buttoned the motor back up and cranked it and found this....
http://s71.photobucket.com/albums/i...on=view&current=video-2011-04-03-12-58-26.mp4
this is a video of the starboard side by the starter. There is a hole cast in the block (my guess is its for a dipstick)...
Its not threaded (that I can see) and oil is flinging out of it while running.
I'm thinking a rubber plug will fix it...
Thoughts?
Bt Doctur
Re: Oil leak found...how to fix?
so where is the dip stick?
bitterboater
If you don't already have a dipstick for the oil, get one and put it there. Your right, that is a good location for a dipstick to be.
The dipstick goes to the bottom of the pan, not in the block. That hole is normally plugged. I usually just carefully clean the oil out of the hole, then use a bolt with an oil resistant sealer/adhesive on it. let it dry and your good to go.
kewlkatdady
yeah the dipstick is on the port side and threads into the bottom side of the pan.
I don't see threads to recieve a bolt...
DonS. if you're sure its threaded, any idea of the size of the bolt and thread pitch?
This is a new block...so I'm sure I just missed this from the old block.
It's not threaded. That is why I said clean the oil out of the hole, (pieces of a rag on a stick and some acetone) and then some sealer/adhesive to GLUE it in and seal in the process. I used the black Permatex sealer used on the intake manifold ends. Don't remember the exact name.
I think it was a 3/8 bolt I used.
kewlkatdady
very cool.
thanks for the info...
BTW I looked at my old block and it has this same thing...but its plugged.
Never noticed it during the motor tear down and build.
