oil leaking out of prop when i lower my outdrive
glasstream86
i lowered my cobra outdrive the other day and a mixture of water and mostly gear lub came out of the area between the prop and the outdrive are my seal goin out internally or is this normal
Gary H NC
Re: oil leaking out of prop when i lower my outdrive
Not normal at all.You have a leak.
Possible propshaft seals,shift shaft seal or the seals behind the impeller pump adapter plate.
A pressure test is needed to verify where it is coming from.
pinellas50
Drain the lower unit and see what's in there.
Repost in the I/O area for the best advice.
